94' trans problem....not downshifting right
Old Jun 16, 2003 | 10:52 AM
bigkidd's Avatar
i hope someone has an idea about what might be wrong.everything was fine until this past weekend now when i downshift its like its not in gear.my rpm's dont go up but if i give it gas the rev will go up until it matches the trany and then starts pulling again.this is hard to explain.it still upshifts fine,just as hard as it ever did.its a 94' w\auto.....any thoughts ????
was wondering if its a trany problem or a converter problem ???
Old Jun 18, 2003 | 12:05 AM
bigkidd's Avatar
or could this be a sensor problem ?
does any of this make sense ?
Old Jun 18, 2003 | 01:33 AM
fbird95's Avatar
Clutch drums are probably slipping. Time for a new trans preferably or a rebuild, watch out though cause a good rebuild can cost almost as much as a new trans and a lot of shops cut corners.
Old Jun 18, 2003 | 03:28 PM
akrott1's Avatar
Are you manually downshifting it? If so you have burned out your overrun clutches.....that is why it is a bad idea to downshift your automatic.
Sounds like rebuild time
Old Jun 18, 2003 | 08:33 PM
bigkidd's Avatar
thanks for your help guys.....
not what i wanted to hear but i guess its time for a new tranny or a rebuild.....and no more downshifting....
thanks again..
Old Jun 19, 2003 | 02:47 AM
revtime's Avatar
Guy who built my tranny said it was no problem downshifting my auto after his rebuild.
We shall see if the junk he built will last in my junk.
force10
Aug 10, 2015 08:30 AM
jackpawt883
Jul 20, 2015 06:32 PM
