94 trans am running rough and popping
Old Mar 3, 2019 | 03:40 PM
94tran's Avatar
My 94 trans am is running rough and popping. I have replaced the opti spark, coil, computer, plugs and wires,
Old Mar 3, 2019 | 07:39 PM
Re: 94 trans am running rough and popping
When is it running rough and popping - cold idle (open loop), hot idle (closed loop), on the road cruising at moderate load, at WOT, all of the above?
At any point have you scanned it for codes or checked the fuel pressure? How old are the O2 sensors? Is the engine basically stock, or modified? If modified, what has been done to it?
What led you to replace those specific parts? Particularly the “computer”.... they rarely fail.
Old Mar 3, 2019 | 07:48 PM
94tran's Avatar
i honestly was just replacing what i thought could be the problem, it does it some on cold start but mostly when its warm. When i pulled the plugs out they were covered in gas. My next step was going to be replacing the injectors
Old Mar 4, 2019 | 09:53 AM
Sounds more like a problem with running rich - many possible causes..... excessive fuel pressure, leaking fuel pressure regulator, faulty O2 sensors (or faulty wiring), exhaust leaks before the O2 sensors, faulty coolant temp sensor, etc.
Back to basics....have you scanned for codes? Have you checked the fuel pressure? You have to answer the questions if you want useful help.
Data log using Scan9495 could help identify the problem. Download free software to laptop, buy or build a cable, log the PCM from cold start thru a WOT pull. Post a .pdf file of the log, and I'll review it for you. A lot less expensive than playing “parts replacement roulette”.
https://www.camaroz28.com/forums/com...95-lt1-874306/
Old Mar 4, 2019 | 11:37 AM
94tran's Avatar
I have not done a compression test but i will do that, when i scanned it i got a a 1 and 3 cylinder miss
Old Mar 4, 2019 | 01:16 PM
Didn’t ask about compression test. And there is no misfire codes in 94 OBD-1. Misfire detection was added in 1996 as part of OBD-2. Were you using a Tech-2 to access PCM data?
Old Mar 4, 2019 | 05:41 PM
94tran's Avatar
I got the car from my brother inlaw and he took it to a shop and they scanned it and told him that it was misfiring on 1 and 3 so he replaced the plugs, wires and opti spark. None of this fixed it so he got tired of messing with it so i bought it. I put a computer in it and changed the plugs out again because they were fouled out, the car misses and pops but if you rev it up it will rev out. I have noticed that the header gaskets need to be replaced
Old Mar 4, 2019 | 07:16 PM
There is NO misfire detection on the 93-95 OBD-1 LT1. Misfire detection requires a crank position sensor, and the 93-95 engine doesn’t have one. Not much more I can do to help if you don’t believe me.
Old Mar 4, 2019 | 07:30 PM
Chimera96's Avatar
OP
before you start throwing parts at it, some of the new ones can likely be bad, scan the car using the free software scan9495.
injuneer is VERY knowledgeable but he or anyone can not help over the internet without solid diagnostic data
you mention you have bad exhaust (header) gaskets.....fix those first. exhaust leak will make the car run rich
also check for things like a cracked intake elbow. Unmetered air entering motor after MAF will make the car run pig rich
Once you get obvious issues fixed, start car in the dark and look very closely at spark plug boots/wires...is there a light show? if so you have bad plug wire(s). Misting them with a little water can help reveal plug wire arc. You may (read should) put the car up on ramps and look from below so you can see ALL of the plug bot. If plug boot has the metal heat shield on it, remove it as the arc can be between the inside of it and boot...making it impossible to see
would also be VERY helpful to simply check fuel pressure to confirm it is not stupid high......or low
Old Mar 4, 2019 | 07:54 PM
94tran's Avatar
I never said i dident believe you, you asked why i replaced all of the parts so i was just letting you know what the guy that i got the car from told me
Ultra_Dog
12
May 5, 2007 07:32 AM
LTgun_94
Aug 11, 2006 06:46 PM
JP94Z
Jul 20, 2005 05:37 PM
Fastbird93
Feb 21, 2005 10:57 AM
HardcoreRM125
Aug 8, 2004 09:17 PM
