94 LT1 vs. 97 LT1
Old Dec 23, 2003 | 04:16 PM
  #16
bunker's Avatar
Yep 93-94(early) had forged rods, 93's had really nice thick casting heads, 96(late) the casting of the heads got worse, although they flowed better then the older versions they couldn't be ported as much as the roof got thinner. Cam's kept on changing around, intake manifold got worse in 96 (smaller ports), the cars kept getting worse like getting bad leather etc... except the improvement in the Camaro interior for 97! Then the LS1 came out & that was nice except it ate oil up to 2000
Old Dec 23, 2003 | 04:29 PM
  #17
dj haf's Avatar
which LT1's came with aluminum and iron heads? man... im curious to know if there's a site out there that gives out every spec on each year of the LT1 like there is for thirdgen camaro's on thirdgen.com > tech data. since im going to be riding around with an LT1, i might as well learn about them and know everything there is to know about them like i know about my L98
Old Dec 23, 2003 | 04:39 PM
  #18
Caprice/Impala/Roadmaster/Fleetwod LT1's are iron heads, smaller cams. Read the first link I posted... its all spelled out in there. Find out about the "Baby LT1"..... 265ci.
Old Dec 23, 2003 | 04:44 PM
  #19
Mtrhds94Z's Avatar
Also remember that the unvented[93-4 LT1] opti is 380 ish .. not the 200 or so that has been quoted above[that's the price for 95-7 vented optis..]..
Old Dec 23, 2003 | 04:45 PM
  #20
ZZtop's Avatar
Sorry to hear about your bad luck. Cheer up its Christmas! things have a way or working out.
Old Dec 25, 2003 | 06:32 PM
  #21
fdxpilot's Avatar
Originally posted by dj haf
well... here's the deal. im jobless right now and im going to have to use my visa to do all of these at my mechanic's shop. i was riding around in my iroc-z (350 L98) and it just died on me. tried to fix it, spent about 100$ trying to fix it, but to no avail, it wouldnt work right. i took it to my mechanic and he told me it has to be rebuilt... so it comes out cheaper for me to get an LT1 and just swap it than having him rebuild it.
There will probably be a lot more involved than just "dropping it in". Radiator willprobably need relpacement or modification, fuel pump, o2 sensors or sims, accessory brackets modified to fit your car. I don't know if I would start a project like this with no cash, planning to put it on a CC. A rebuild on your L98 will probably be cheaper.
IMHO
Old Dec 25, 2003 | 06:48 PM
  #22
lt1hatesme's Avatar
before i bought my 4th gen, my 3rd gen LG4 went and **** itself. so i thought about the LT1 swap and i contacted a few people and the cheapest price i found, and this is from someone who does it all the time, and is even a thirdgen.org board member, was over 3G's for just the swap. not to mention all the accessories, the engine (duh) and im pretty sure you would need a new exhaust set up, and a new radiator as mentioned above. i think the front sway bars are different aswell but i dont know if it would still work or not, it might. but its gonna be really expensive and some serious down time to get the engine (tranny??) and wiring done.
Old Dec 25, 2003 | 07:20 PM
  #23
carlos64030's Avatar
Here is some good info for you: http://www.capricess.com/technical/L...ld/ar99928.htm
It should answer some your questions.
Old Dec 25, 2003 | 07:22 PM
  #24
Here's something else that will help you out: http://www.lt1powered85z.cz28.com/custom.html
Old Dec 25, 2003 | 07:33 PM
  #25
I honestly believe that re-building your L98 will be a LOT cheaper than trying to swap in an LT1. If you could pull and re-install the engine yourself, you could probably have your motor rebuilt and running for less than $1500.
Old Dec 25, 2003 | 08:52 PM
  #26
dj haf's Avatar
ya, im going to re-build it because i found the price to be totally out there to do the swap, lol. going to have it rebuilt with a higher cr to give me a little bit more power. moving from 9:5:1 to 10:5:1... what kind of gains do you think i'd find? im going to get forged flat top pistons, port out my heads and some thick head gaskets. any other ideas to get close to 10:5:1? thanks guys... ehh now i kinda got off the original subject of the post, lol
Old Dec 25, 2003 | 10:43 PM
  #27
ssbowtie1's Avatar
10.5:1 with iron l98 heads =
Unless you have 93-94 gas around.
Old Dec 26, 2003 | 02:39 AM
  #28
dj haf's Avatar
yeah... 93 octane is all i put in her since i got her... what do you guys suggest i boost the cr to for optimal power?
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Jan 11, 2015 06:10 PM
NewsBot
Dec 28, 2014 06:20 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
