94 Lt1 batch fired or sequential fired
Old Sep 21, 2016 | 05:56 AM
frankrizz's Avatar
Hey Guys,
Need some clarification. Is a 94 lt1 Batch fired or sequential fired?
The reason I ask is that I think one of the fuel injection electric connectors on the r/s may have been reversed. Don't know if this matters.
Old Sep 21, 2016 | 06:27 AM
Re: 94 Lt1 batch fired or sequential fired
It is sequential. The injector plugs are numbered (on a stock harness, anyway).
Old Sep 21, 2016 | 08:01 AM
frankrizz's Avatar
Thanks so much! That being said From front to rear right bank reads:
PED 39, PED36 PED34, PED35
From front to rear left bank reads:
PED27, PED35, PED26, PED39
Is this the correct order?
Old Sep 21, 2016 | 11:30 AM
You should see the numbers 1 thru 8 on the injector harness connectors. Starting at driver's side front 1, 3, 5, 7. Starting at passenger side front 2, 4, 6, 8, These are the stock 6 and 8 connectors on the 94 that I bought brand new in 94 and still have (probably one of the few stock/unaltered parts in the photo):
Old Sep 21, 2016 | 03:04 PM
If you need to go by the wire colors, use this schematic. One wire will be pink and the other will be various colors.
Old Sep 21, 2016 | 09:51 PM
GaryDoug's Avatar
Prominent Member
The "PED" means Packard Electric Division. It just tells you what part of GM made the connectors.
frankrizz
Dec 27, 2015 08:43 PM
mike24
Aug 7, 2002 10:06 PM
Michael Ozorowsky
Jun 19, 2002 03:36 PM
Z-4-ME
Aug 13, 2001 10:35 PM
