94 Hub and Balancer on a 95?
Old Feb 21, 2011 | 08:54 AM
95mysticta's Avatar
Hey guys cant find any info and before i yank the hub off my 94 motor i want to be sure if will fit a 95 cover on my new built motor. Thanks!
Old Feb 21, 2011 | 09:12 AM
andysc's Avatar
Re: 94 Hub and Balancer on a 95?
The front timing cover is different from a 94 to 95
http://www.nookandtranny.com/Info_LT1.html
Scroll down to almost the bottom, and it will show you the 3 types of front timing covers. The opti opening in the middle is the biggest difference. Most 94's had the smaller or spline drive, some 94's thru 97 had the larger opening for the redesigned opti. They go thru the steps of going from a 92-94 spline opti to the newer design, but it requires a new opti
hth
andy schuck
Old Feb 21, 2011 | 09:32 AM
The 94 and 95 hubs are identical, and will fit either the 94 or 95 timing cover. I'm going to assume you used the 95 timing cover because your new engine has a vented Opti.
There is no "balancer"... its a neutral balanced harmonic damper, so it can be used with any LT1 engine.
Old Feb 21, 2011 | 12:06 PM
95mysticta's Avatar
Thanks Fred just wanted to be sure and yes im converting to a vented system in hopes of prolonged life. Just wanted to be sure before i rip it off my old motor and on the new one it will fit as i wouldve started looking for a used one.
AviatorDave
Dec 19, 2016 06:35 PM
Jeff1904
Jun 5, 2016 05:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Boss002
Jul 24, 2015 10:47 AM
RallyRed701/2
Jul 20, 2015 11:18 AM
