94 Forumla problem.
Old May 19, 2005 | 05:53 PM
mike82usf's Avatar
94 Forumla problem.
I have a 94 formula with about 83K miles and an automatic tranny. Whenever I put the car in gear it jerks back and forth like it wants to go forward. But once I give it gas it is fine. It doesn't do this in neutral or park. Any ideas what could be wrong?
Mike
Old May 19, 2005 | 06:43 PM
brians96Z's Avatar
Re: 94 Forumla problem.
Man that sounds like a weird one. Have you checked your trans fuild? Could be a torque convertor issue too.
Old May 19, 2005 | 06:45 PM
Fuels94TA's Avatar
Are you on the brakes when this happens?
Old May 19, 2005 | 06:53 PM
mike82usf's Avatar
yes I'm on the brakes.
Old May 19, 2005 | 06:58 PM
Fuels94TA's Avatar
Then it sounds like you have brake problems. Might have air in the system, so have them check and bleed.
Old May 19, 2005 | 07:00 PM
mike82usf's Avatar
I can throw the car into neurtral and the car will stop fine.
Old May 19, 2005 | 07:13 PM
Fuels94TA's Avatar
When you put it in neutral, it's not making a forward motion, so it takes less energy to stop the car. Instead of it being in gear.
Old May 20, 2005 | 12:32 PM
SixSpeedShifter's Avatar
The forward thrust being created by the engaged tranny is virtually non-existant compared to the momentum of the moving car. This definately sounds like a tranny problem... Sorry I dont know too much about autos.
brothaslide
Jan 9, 2016 12:11 PM
MDZ28
Sep 7, 2015 09:16 PM
4586
Aug 22, 2015 01:09 AM
War Engine
Aug 21, 2015 05:28 AM
jerrysims71
Aug 15, 2015 12:47 PM
