94 formula code 29
Old Feb 19, 2007 | 07:37 PM
1995m6z28's Avatar
94 formula code 29
I have a 94 firebird formula that is showing a code 29, it comes on with the engine fan, and goes off with the cooling fan, anyone had this problem before? also the car has a starting problem were it takes an unusual amount of time to crank, it turns over at normal speed it just takes a lot more time to actual start, my 95 z28 fires right up as you hit the key. fuel pressure shows within specs. Not a super emergency just annoying, it always starts and runs strong, just takes too long to start, sounds like a piece of crap when it takes a couple of times to crank.
Kevin
Old Feb 19, 2007 | 10:32 PM
The standard answer for DTC 29 is check the AIR pump fuse. The fans come on in the presence of most DTCs. That is normal.
Jazsun
Dec 29, 2014 12:14 PM
Jul 4, 2005 05:00 PM
91Bird305
Aug 5, 2002 01:39 PM
jrp4uc
Jun 19, 2002 06:20 PM
