94-95 Y-pipe on a 97???
Old Apr 19, 2003 | 12:10 AM
1982z28with18s's Avatar
Can a Y-pipe from a 94-95 work on a 97 if I get rid of the cats and use 02 simms. Also could the borla y-pipe work? My cat's are clogged and I am thinking about a borla y-pipe and then a 3" bullet muffler and dump right before the axel with some 3" piping. Currently I have all stock exhaust except I cut off the muffler. Thanks
Old Apr 19, 2003 | 12:17 AM
Dr.Mudge's Avatar
They will not mate up with your manifolds, you will need to swap those too.
Old Apr 19, 2003 | 12:54 AM
turbo_Z's Avatar
DM is right..
i can hook you up with some 95 manifolds if you are interested. they are a friend of mines but im sure hed let them go cheap. you could always just buy 94-95 headers like i did and that will get rid of the cats. but as for them being clogged... if youre trying to track down a problem then i would look at soemthing else. your car has 2 cats so i really dont see how they would get clogged.. mine were fine when i pulled them off at 70k.
Old Apr 19, 2003 | 01:29 AM
I think I will just go ahead and go with long tubes. I was just curious if the y-pipes matched up or not. If they would have I would've considered getting the borla y-pipe and then run a stall, but I think I will just put my money into headers instead. Thanks for the help.
Quickss96
Jan 29, 2016 05:56 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
Noer
Parts Wanted
May 4, 2015 04:58 PM
Pig Pen
Parts Wanted
Apr 30, 2015 08:41 AM
