93z28 timing chain replacement ?????
Old Apr 2, 2007 | 03:17 AM
504rveasy's Avatar
Question 93z28 timing chain replacement ?????
could anyone tell me if they make a direct replacement timing set kit for a 93LT1 other than GM ?
Old Apr 2, 2007 | 07:55 AM
There is not much out there that is better (or even offered) for 93-94s. Doug Rippie sells a set, but it is very expensive.
Old Apr 2, 2007 | 08:05 AM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
I'm trying to figure out whether to put a new timing set on my 94 when I change the opti. My car has about 100K miles on it and I'm not sure whether it would be worth it or not. Is there any way to tell other than direct examination whether the chain and gears should be replaced? If you remove the timing cover it seems to me that you may as well go ahead and change the stuff while you're in there.
Anyone have any thoughts?
How much is the Rippie replacement and what would be the advantages of that set over an OEM replacement?
Old Apr 2, 2007 | 08:30 AM
Z-RATED94's Avatar
When we did the H/C swap on my car (94), we just put a GM stock replacement on it. The old one was the oringinal and only had 28k on it, but since it had to come off and I didn't have the money to convert I felt that was good enough. I mean, how many storys have you heard about where a new or low mileage timing set has crapped out? If the stock shortblock gives up the ghost, well then its a different story.
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
