93 z runs fine when open loop,like crap in closed, WHY?
Old Aug 17, 2006 | 06:32 PM
  #16
Fbody1's Avatar
Re: 93 z runs fine when open loop,like crap in closed, WHY?
I am using a scan tool to get the readings from the PCM I think it is actron (kinda cheap) is it possible the fuel regulator is bad?
Old Aug 17, 2006 | 06:46 PM
  #17
Kevin Blown 95 TA's Avatar
Definitely something to check. If yoouget a gauge on the schraeder valve, check the readings with and without the vacuum hose and see what you get.
Old Aug 20, 2006 | 08:14 AM
  #18
Guest47904's Avatar
Guest
Mine had a problem with closed loop in that the PCM always saw a rich O2 on the driver side and would run like crap. Forced it to open loop and it ran as well as any could in open loop. Changed the O2 as anyone would and scanned it with KOEO and you could watch the O2 reading drift to completely pegged rich. Hadn't even run the engine with the new O2 yet mind you. I have found that with KOEO the O2 readings should gradually drift to a lean reading, not full rich obviously.
Double checked for bad wiring to the O2 and finally found out the PCM circuit used for the O2 was defective. So new PCM it was. Now that problem is fixed I can focus on the "other" problem.
DirtyDaveW
Dec 1, 2016 05:37 PM
warmeck
Feb 5, 2015 11:04 AM
97SSdude
Dec 31, 2014 07:43 PM
nophix
Nov 30, 2014 10:26 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
