93 Z leaking oil out of front cover
Old Aug 7, 2006 | 02:17 PM
Green95Z28's Avatar
I just pulled everything down and changed the water pump seal and o rings on the drive for it... Fired it back up and its leaking again.. I checked the opti spark seal when I had it apart and it looked brand new (only 10k miles on motor) but it seems like that is the one that is leaking... Is there any special way to install it??? It is definately not the pan because I watched it leak out from the timing cover...
Also, the car seems to over heat with the AC on... If I sit at idle for a while on a warm day the car will over heat with the AC. It will not over heat when it is off, and as a matter of fact it cools down rather quickly when the AC is off.
Thanks again for ANY help.
Old Aug 7, 2006 | 02:20 PM
Javier97Z28's Avatar
Moderator
Re: 93 Z leaking oil out of front cover
Are you sure you put the water pump seal on correctly? That can be a tricky one to not rip and get right.
Old Aug 7, 2006 | 02:23 PM
Green95Z28's Avatar
I used a small sleeve to put around the shaft coming out of the front cover so it would not cut the seal (the second time ) I cut the first one and changed it again... Thanks for the quick reply!
Old Aug 7, 2006 | 06:44 PM
Matts1994Z28's Avatar
i have the same exact issues!
Old Aug 7, 2006 | 07:57 PM
Green95Z28's Avatar
Well i tore it all down and its definately the seal in the front cover for the opti spark, the water pump one is still good and no loose oil around it... Are there any tricks to installing the opti spark seal so it wont leak?
Old Aug 7, 2006 | 07:58 PM
Moderator
Hrm... not sure then.
The opti seal has no real particular way of installing. The one that always works for me is to tap it in evenly with a block of wood and a hammer, then snug it in properly.
Old Aug 7, 2006 | 08:14 PM
Green95Z28's Avatar
well i guess the fact that i pushed it back in with my fingers should be a good indication why its leaking lol
Old Aug 7, 2006 | 08:23 PM
Moderator
lol, yah I can't imagine it fitting in there by just pushing it in. It should seat flush with the timing cover.
HectorM52
Jul 30, 2017 11:46 AM
alex5366
Feb 17, 2015 10:43 PM
Jessie4tin
Jan 7, 2015 08:53 AM
Queens94z28
Dec 20, 2014 09:11 PM
1LEThumper
Jul 14, 2003 12:45 PM
