93 z-28 cooling problem
Old Mar 12, 2008 | 07:11 PM
West z-28's Avatar
Question 93 z-28 cooling problem
I have a 93 z-28 that won't get warm. The moter temp only gets about 130 when moving
Old Mar 12, 2008 | 08:08 PM
dangalla's Avatar
have you tried to replace the thermostat
Old Mar 12, 2008 | 08:56 PM
West z-28's Avatar
93 z-28
I replaced the thermostat twice and it still holds about 130 especially when it is cold
Old Mar 12, 2008 | 08:58 PM
95 Civic's Avatar
Thermo stuck open?
Old Mar 12, 2008 | 10:02 PM
Coolant sensor or gauge problem? Compare the reading with the computer.
Old Mar 13, 2008 | 07:19 AM
West z-28's Avatar
93 z-28
the thermo is new and the heat only blows warm while at an idle or at about 2500 rpms after that it goes cold
Old Mar 13, 2008 | 04:52 PM
West z-28's Avatar
93 z 28
could the temp senser for the gauge be causing this
Old Mar 13, 2008 | 05:25 PM
The 93 dash coolant temperature gauge is very misleading. It is the only year where the lowest mark is shown as 100*F. In all other years, the lowest mark is labeled as 160*F. A lot of 93 owners make the comment that their gauge never gets very high.... I think the 93 gauge is simply mislabeled.
Shoebox has the info, as usual:
It could. That's why I suggested you check it.
Old Mar 13, 2008 | 05:26 PM
Pyrodawg's Avatar
are u going off the gauge? because the gauges for these cars arent exactly symmetrically accurate... do u have a laptop and cable to hook up to it and read the actual temp... do ur fans kick on?
injuneer beat me to it
Old Mar 13, 2008 | 05:49 PM
West z-28's Avatar
93 z-28
no the fans dont kick on and the moter temp is between 130 and 145 when driving. the computer tells the car that it is cold so it runs real rich and blowes by raw gas. i checked the temp with a elc gauge and the computer
Old Mar 13, 2008 | 05:52 PM
West z-28's Avatar
93 z-28
in those pic above my car runs lower than that 93 pic when moving and about 210 at an idol
Old Mar 14, 2008 | 09:29 AM
If you have verified that the actual coolant temp is 130*F at high speeds, your t'stat isn't closing.
Old Mar 14, 2008 | 04:35 PM
West z-28's Avatar
93 z-28
I've tried two new thermostats, 1 cheap and 1 expensive, both get the same result.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
Mar 13, 2016 03:39 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
MattFick
Feb 15, 2015 10:16 PM
