93 LT1 Pulse Error - Dealership has 'no clue'
Old Aug 10, 2005 | 01:13 PM
  #16
guruerror's Avatar
Re: 93 LT1 Pulse Error - Dealership has 'no clue'
I just received an update from the dealership...I think they are getting a little irritated by me as I have been printing out all of your feedback thus far and faxed it to the service manager...
Anyhow...they inspected the wiring harness and have found 'gaps' in the connectors that may indicate bad connections. They are tooling around with it now; hopefully the harness is the issue as it is a more affordable solution.
In regards the the distributor unit that I had the previous mechanic put on last month, the part number was 10457702. According to a previous poster I am assuming that this included the cap, rotor, and Optispark (the mechanic says it did)...is this correct? If not...what is the part number for the Optispark unit?
Thanks again for all of your feedback...hopefully the Z will hit the pavement again this week.
Old Aug 10, 2005 | 01:23 PM
  #17
JBird33's Avatar
That is the entire Optispark, and it is the correct one for your year. If that is the case, then I am almost positive it is your wiring harness.
Old Aug 10, 2005 | 01:26 PM
  #18
MyTMous's Avatar
I went through 3 new opti's before I got a good one, and I had the same error on 2, hi res failure, on the other 1 I got a high and low res failure(with both of the those the car will shut off, mine did in a curve at 50mph)
so just because it was new doesn't mean it's a good part,
but also check the wiring to the opti, that can go bad also.
Old Aug 13, 2005 | 02:37 PM
  #19
guruerror's Avatar
Got the car back yesterday...they (dealersip) reported that several of the wiring harness connectors had "gaps" and could not possibly be making solid connections.
They replaced all the connectors on the PCM end and their 'Corvette mechanic' took it home and put 70 miles on it as a road test. I've put an additional 30 on today...seems like the problem is resolved.
Thanks for all of your help...I'm sure the dealership thanks you too as I constantly forwarded all your posts to them...probably drove them crazy.
Thanks again...this is a great forum with a good group of Z enthusiasts.
Old Aug 13, 2005 | 08:32 PM
  #20
I'm sure they enjoyed my comments.
DirtyDaveW
Dec 1, 2016 05:37 PM
nophix
Nov 30, 2014 10:26 PM
jeff94z28
Sep 11, 2002 02:01 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
