93 LT1 Oil Pressure Question
Old Aug 3, 2008 | 02:32 PM
93LT1MaroBoy's Avatar
i recently bought 93 camaro i was wondering about the oil pressure its at idle the gauge sits around 60-80 psi with 10-40w. Is this good for a engine with 131,000 because i wanted to know is it a possibility that the engine has been swapped out?
Old Aug 3, 2008 | 07:10 PM
Sounds more like the oil pressure gauge is faulty. Have you checked the sending unit and harness?
I'll move this to "LT1 Based Engine Tech"..... this isn't an "Advanced Tech" question.
Old Aug 3, 2008 | 07:27 PM
ok, the sending unit is new and the gauge seems to work correctly. What is considered normal?
Old Aug 3, 2008 | 09:09 PM
maverickmk's Avatar
I think 60 - 80 at idle is a bit high, should be closer to 40 psi, according to GM factory specs for an LT1: oil pressure should be at 6 psi at 1,000 rpm; 18 psi @ 2,000 & 24 psi @ 4,000 rpm - at operating temperature
Old Aug 3, 2008 | 10:31 PM
60-80 on initial start up in the morning, idle it drops to around fifty
Old Aug 3, 2008 | 11:50 PM
YodiBrodi's Avatar
6 Psi !!!!!!!!!!!!!!!
Old Aug 4, 2008 | 05:26 AM
The GM spec for 6psi is the minimum acceptable pressure, and probably the set point for the "check gauges" light to come on. I suspect most new LT1's would have idled at 30-35psi. There's a 60psi relief spring in the pump, so pressure should never exceed 60psi.
Old Aug 4, 2008 | 05:43 AM
ACE1252's Avatar
The average idle pressure for the LT1 is around 20 psi. The oil that Chevy recommends for the LT1 is 5W-30. Change it and see if your pressure gets back to spec.....If you have 60-80 psi at idle....something is wrong.
Old Aug 4, 2008 | 10:19 AM
karpetcm's Avatar
my oil pressure on my 93 Z would hardly drop below half way point warm and cold was about 80. Whoever saw this was suprised and couldnt figure it out. Ive had several mechanics look at it and the oil pressure unit was working just fine i even had it replaced just in case.
Old Aug 4, 2008 | 12:29 PM
twcblackhand6970's Avatar
The oil gauge on my car reads about 56-58psi while I'm driving and about 25-30 at idle. Using 10W-30. Idk if that's normal or helps at all.
Old Aug 7, 2008 | 02:56 PM
Mine Basically Runs The Same And Has Some What Alot Of Mile Which Is Why I Run The 10-40w
Old Aug 10, 2008 | 12:24 PM
slingshot's Avatar
I have high pressure, but i run a mellings select pump that is 10 % higher volume. I also run 15-50 Mobil 1. Mine around idle is 30 psi.
Jessie4tin
Jan 7, 2015 08:53 AM
NorthPoleDev
Dec 31, 2014 03:20 PM
cmdeshon
Dec 27, 2014 10:06 AM
jayblev95
Dec 1, 2014 06:55 AM
Jul 4, 2005 05:00 PM
