93 LT1, How do I know which injector plug is to which injector?
Old Oct 11, 2006 | 01:19 PM
Mike96z's Avatar
I have a 93 LT1 Formula and I unhooked the wiring harness but I don't know which injector plug goes to which injectors. My 96 LT1 has the numbers of the cylinders on the side but these are much older on the 93 and say nothing. Please help, it would be nice. Thanks
Old Oct 11, 2006 | 01:27 PM
MyShibbyZ28's Avatar
Re: 93 LT1, How do I know which injector plug is to which injector?
The plugs that go into the injectors have tiny numbers inprinted on them.
Old Oct 11, 2006 | 01:28 PM
FuryZ28's Avatar
Well, 93's use batch-fire injection, meaning it activates the injectors by each cylinder bank. 94 and later used sequential-fire injection, meaning the injectors activate one cylinder at a time. Anyways, to answer your question, so long as you keep the same 4 injector plugs on their appropriate sides (I think you'd have to literally flip the harness upside down in order to reverse it) you can plug them in any order. One of the benefits to owning a 93...
Old Oct 11, 2006 | 03:21 PM
Mike96z's Avatar
thanks man
Alex Barnes
Jan 24, 2015 10:21 PM
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
Jul 4, 2005 05:00 PM
