93 LT1 Cylinder heads.
Old Jul 12, 2006 | 11:46 PM
1FstFormulaV8's Avatar
What are the part number for cylinder heads? Right and Left sides. Assembled or not would be fine.
Thanks.
Old Jul 12, 2006 | 11:51 PM
Re: 93 LT1 Cylinder heads.
There is no "left" and "right". The heads are identical on both sides. You just have to move the plug for the rear steam tube to the front on one side.
Old Jul 13, 2006 | 02:19 PM
So I can send them to sent to Lloyd to have them ported and assembled. To cut down on downtime?
Old Jul 13, 2006 | 02:39 PM
Edlebrock heads are around $519 a piece. I'm not for sure how much stock ones cost, or if they are even available. I guess I could search around for some.
Old Jul 13, 2006 | 02:43 PM
You don't need to buy a set of NEW stock heads... you can get a good used set for low $$$. Or he has heads to sell you. Someday I might sell the ones that are sitting in my garage .
Old Jul 13, 2006 | 02:53 PM
Interesting. I've been searching around. I'm really cautious about Ebay. There's a few sets on there that are going for less than $400. Not too bad.
Old Jul 13, 2006 | 02:56 PM
You might also want to read this thread, that explains the differences between the "early" and "late" LT1 heads, either of which will fit your 93:
http://web.camaross.com/forums/showthread.php?t=427346
Old Jul 13, 2006 | 03:06 PM
Thanks Injuneer! Looks like I got lucky with the 93 heads. Just finding a good set. That's going to be tricky.
Old Jul 13, 2006 | 06:42 PM
1racerdude's Avatar
The last set I got were 250 with valves and springs.
Old Jul 13, 2006 | 07:28 PM
LenT1's Avatar
Yea I see sets go for 250-300 all the time...buy em used on these forums..
pimpss96
Feb 12, 2015 01:28 PM
MadMav
Feb 6, 2015 11:02 PM
Chris Anderson
Jan 27, 2015 08:30 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
