93 Knock sensor?
93 Knock sensor?
i did a search but didnt really see what i am looking for. On my 93 Z i am looking to put a lt4 knock module on it, but what i have seen said they are for 94-97. Does the 93 with speed density have a different module or what. Also is there a good place to get one besides Ebay.
Re: 93 Knock sensor?
The 93 use a different type of engine management. It uses an ECM with a removable "chip". This style doesn't have a knock module. If I remember correctly the knock sensor functions are programmed in a 93.The knock modules are for the 94+ PCM. The PCM is flash programmed and the knock module cuts down on the PCMs reading of false knock.
14
Aug 11, 2015 12:03 PM
Noct
Jul 14, 2015 01:18 AM
