93 IAC problems..steady 160 count..
datamaster is showing a steady 160 count at idle. ive used shoebox's site to test the IAC circuit and ive got infinite resistance on A/B and C/D. ive checked the grn/wht and grn/black back to the pcm connector and they check out fine with only .1 resistance. does that leave the pcm as being faulty?
thanks
thanks
Re: 93 IAC problems..steady 160 count..
My guess would be that this is because you have a 383.
Clean out the IAC and crack your TB blades open a bit. Do a search on drilling the IAC bypass hole bigger to allow more air in at idle.
ive tried cracking the blades and i was looking into the drill mod but now i think there may be another underlying issue.
should i be checking the IAC itseslf or the wiring from the pcm. i assumed it was a wiring check but after reading the instructions again i see it seems to be a check on the valve itself.
thanks
thanks
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
tdigger9899
Sep 7, 2015 10:56 AM
