93 IAC problems..steady 160 count..
Old Oct 16, 2006 | 01:41 PM
93black-ta's Avatar
datamaster is showing a steady 160 count at idle. ive used shoebox's site to test the IAC circuit and ive got infinite resistance on A/B and C/D. ive checked the grn/wht and grn/black back to the pcm connector and they check out fine with only .1 resistance. does that leave the pcm as being faulty?
thanks
Old Oct 16, 2006 | 02:18 PM
Gripenfelter's Avatar
Re: 93 IAC problems..steady 160 count..
My guess would be that this is because you have a 383.
Clean out the IAC and crack your TB blades open a bit. Do a search on drilling the IAC bypass hole bigger to allow more air in at idle.
Old Oct 16, 2006 | 02:24 PM
93black-ta's Avatar
ive tried cracking the blades and i was looking into the drill mod but now i think there may be another underlying issue.
Old Oct 16, 2006 | 06:04 PM
Since Shoebox's test procedure suggests that you should have 40-80 ohms between "A to B" and "C to D", it would appear that your IAC valve is not working. If its not working, the PCM will continue to increase the IAC "counts" until it reaches the upper limit of 160. But since your IAC may not be moving at all, the PCM has no way of knowing that.
Old Oct 16, 2006 | 09:39 PM
93black-ta's Avatar
should i be checking the IAC itseslf or the wiring from the pcm. i assumed it was a wiring check but after reading the instructions again i see it seems to be a check on the valve itself.
thanks
Old Oct 17, 2006 | 12:07 PM
Shoebox's instructions tell you how to measure the resistance across the coils of the IAC motor.
Old Oct 17, 2006 | 03:52 PM
93black-ta's Avatar
IAC was stuck all of the way shut. I assume that's what been causing my DTC 34.
thanks
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
truecontr3
Oct 11, 2015 09:30 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
tdigger9899
Sep 7, 2015 10:56 AM
