93 balancer, No key, shed some light?
Old Jan 5, 2004 | 02:08 AM
ss6ixspeed's Avatar
Why does my buddie's 93 Z have a notch on the hub for a key, but the balancer doesn't have one. It's back on and torqued to spec of I believe 98 ft.lbs but we're concerned with slippage. Pretty much stock, how much hp will this balancer without a key hold? Any ways to modify without buying a new hub and balancer?
Thanks.
Old Jan 5, 2004 | 02:41 AM
QCKZ28's Avatar
all LT1's are made that way. you can buy a keyed hub from www.thunderracing.com but i wouldnt worry about it unless your making serious HP or have forced induction.
jesse
Old Jan 5, 2004 | 02:42 AM
BadAssed93Z's Avatar
have a 93 and just asked basically the same question earlier today.
the hub is a pressure fitting there is no key
torque it up and it will hold
Old Jan 5, 2004 | 06:06 AM
Mtrhds94Z's Avatar
Torque spec on the crankshaft hub bolt is 75 ft lbs..
The Seer
Nov 20, 2014 06:32 AM
JasonD
Jul 15, 2002 02:17 PM
ced8
Jun 24, 2002 09:12 PM
ced8
Jun 24, 2002 11:11 AM
