installing new rings
Old Jan 4, 2004 | 05:49 PM
marshall93z's Avatar
bore size is fine but was wondering what was needed for new rings. do i just put new crosshatchings or what?
and what about the ridge at the top of the cylinder, is that ok to be left there.
thanks for any help
Old Jan 4, 2004 | 05:53 PM
I would imagine you would want a machine shop mic your cylinders before deciding on rings. The ridge should also be taken care of if they do any honing/boring.
Old Jan 4, 2004 | 08:38 PM
wicked_95z's Avatar
Listen to the man.
You will need to remachine the cross hatching in the cylinder. That is important to the rings sealing. Also if you have that notciable of a lip at the top of your cylinder you may be looking at having to bore it over.
Old Jan 5, 2004 | 12:49 AM
it doesnt really need new rings, i was just going to do it while i had the motor down putting bearings in it.
Old Jan 5, 2004 | 06:09 AM
Mtrhds94Z's Avatar
Minimum, ream that ridge[or new rings will break] and hone it..
That's assuming you know it's within spec[bore]
Nov 18, 2023 07:21 PM
1963SS
Feb 6, 2015 10:05 AM
ChrisFrez
Feb 1, 2015 08:26 AM
GA93FORMULA
Jul 24, 2002 11:38 PM
