93' with a 96' swap
Old Sep 28, 2009 | 01:41 PM
93'96'swap's Avatar
Exclamation 93' with a 96' swap
i bought a camaro z28 93' f body with a 96' 5.7 V8 with trans put in what can i do to make get up and go better on the cheap end
Old Sep 29, 2009 | 05:12 AM
What computer is running the engine - 93 ECM or 96 PCM?
Old Sep 29, 2009 | 10:54 AM
n4b's Avatar
n4b
I was thinking the same thing,I just put a 95 motor in a 96 with the 95 harness, Computer and trans but it would not start, I ended up having to use the 96 harness with the crankshaft sensor wire that goes on the front of the 96 opti case, It satrted and can drive but it stillneeds the signal from the sensor which the 95 does not have.
Hopefully I can trick the signal some how.
Old Sep 29, 2009 | 11:08 AM
bw_hunter's Avatar
The CPS can be tuned out....
Old Sep 29, 2009 | 11:56 AM
n4b's Avatar
n4b
How would I have that done?,Would I have to get the computer remap or could I do it myself andhow?,Thanks for youe response.
Old Sep 29, 2009 | 12:25 PM
The 95 and 96 harnesses are not identically pinned out. The CKP has nothing to do with it not starting or running. The engine will run with the CKP disconnected.
Reprogramming would need to be done to turn off the reporting code.
BTW, you have successfully hijacked the OPs thread.
Old Sep 29, 2009 | 12:35 PM
n4b's Avatar
n4b
sorry about that but thanks for your response.
Old Sep 29, 2009 | 06:38 PM
ACE1252's Avatar
What do you mean by the above? You looking for more power? Will the car not start? Or is it down on power compared to the original motor?
David Dempsey
Mar 12, 2016 12:42 AM
blac94Z
Nov 4, 2015 01:59 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
