918 springs on LT1 heads
Old May 17, 2006 | 10:56 AM
  #76
j0n's Avatar
j0n
Re: 918 springs on LT1 heads
I saw on some parts site that you could run stock retainers with the 918 springs...is this true/safe?
Old Jun 19, 2006 | 11:56 PM
  #77
Heatmaker's Avatar
Advanced Member
What the hell is the part number for the shimss that fit the beehives?
Old Jun 20, 2006 | 12:10 AM
  #78
seawolf06's Avatar
I didn't use any shims for mine and haven't heard of any.
Old Jun 20, 2006 | 12:22 AM
  #79
Heatmaker's Avatar
Advanced Member
So without shims just how are you supposed to adjust these things?
With just the Seats?
Old Jun 20, 2006 | 12:25 AM
  #80
seawolf06's Avatar
I made sure to get the +.050 locks to ensure I won't have coil bind. If you want a lower install height, get the regular locks.
Old Jun 20, 2006 | 06:05 PM
  #81
Stoopalini's Avatar
I used Comp Cams Shim Kit p/n# 7453 when I installed the 918s with Scorpion 1.7 RRs. the complete parts list I used is here.
Thomas.
Old Jun 22, 2006 | 09:39 PM
  #82
EDS Z28's Avatar
Originally Posted by Wckd94Z
I'd do that right quick man... I was using the GMPP 1.6s and I specifically checked for clearance between the rocker and the spring retainer, looked fine when I installed them. Pulled the valve covers 300 miles later to lash, and i see a bunch of aluminum floating around, pull a rocker and see big grooves worn into them.
remember i was using the comp +.05 locks as well, hope all that crap doesn't get into your bearings or clog your oil pump, when I changed the oil it was all glittery now someone explain why I still have fantastic oil pressure?!?!?!
also thank you truedualws6 for chiming in, seems like you're the most knowlegeable on this subject, I just learned from ya also I'm still driving 60 miles a day in stop n go southern california traffic with the CC306!
Ya well I checked it out this afternoon since I had to check out a header leak, decided to pull the driver side valve cover. Not too bad, but you can tell the round steel washers on the roller rockers are hitting the tops of the valve locks and the retainers. The locks are forged steel and the retainers are chromoly steel (thank god!). It basically looks like no damage was done, but I don't feel good about it so I am going to swap to the non-self aligning rollers with guide plates. I wish I knew about this about a year ago, I went thru dozens of posts and never read any problem with the SA rocker arms and +.050 locks. It's just something I overlooked. I have around 3-4K miles on the new valvetrain.
Any suggestions on NSA roller rockers and guideplates? I do have the crane chromoly pushrods, I believe these are hardened.
Old Jun 22, 2006 | 11:41 PM
  #83
seawolf06's Avatar
Chromemoly > hardened. I went with the 1.6 Pro Mag RR with a larger 7/16" stud. I didn't want to chance anything. Oh, and GMPP guideplates.
Old Jun 23, 2006 | 08:21 PM
  #84
EDS Z28's Avatar
That's the route I was thinking. I think the Pro Mags have the best reputation. Supposedly the bodies are warrantied for life.
I already have the arp 3/8" rocker studs, would it be worth it to upgrade to 7/16"? I wonder if the 3/8" are sufficient.
Do the center bolt valve covers need clearancing?
And why GMPP guideplates? Is it part #14011051?
Thanks-a-lot
Old Jun 24, 2006 | 02:24 AM
  #85
seawolf06's Avatar
3/8 studs should be sufficient, but it depends on what cam you're running and how hard it is on the valve train. If you think you're ok with a mild cam, then go for it. The valve covers will need to be clearenced some, do a search to see where. GMPP guideplates are the only ones that will work CORRECTLY on the LT1.
Old Jun 24, 2006 | 09:48 PM
  #86
EDS Z28's Avatar
Just a follow up:
All the locks (keepers) on the intake valves were slightly damaged, grinded & grooved on the very tops where the valve spring retainer is located. The exhaust locks were barely touched. The tops of the valve stems looked perfect. It's a good thing I caught this, it probably would have caused major problems later on....
So far I noticed that one of the lifter retainers/clips has a small crack, it doesn't look too bad, but it has caught my attention due to all the bad talk about these lifters lately. Obviously this is an engineering flaw in the lifter which needs to be fixed. We should all get our money back on these things, but you know how it goes, racing parts are not warrantied.
oldschool
Feb 9, 2016 09:21 PM
MadMav
Feb 6, 2015 11:02 PM
95chwagon
Jan 13, 2015 09:19 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 27, 2014 09:41 AM
