918 spring question
Old Feb 16, 2006 | 08:07 PM
  #16
Josh'95Z28conv's Avatar
Re: 918 spring question
Originally Posted by Jon A
Interesting. Learn something every day....
I wish I learned that before he told me the same thing in my "My LT1 is fubar" thread
Old Feb 16, 2006 | 09:37 PM
  #17
Jon A's Avatar
Ah, I had missed that one. Sorry it happened, Josh.
Old Feb 17, 2006 | 01:31 AM
  #18
95ttoplt1's Avatar
Originally Posted by Stoopalini
Notice they do not list numbers for the 26918s after 1.15. What is also interesting, is they recommend a 1.80 install height and then say the spring is good for .600 lift. This puts the spring at 1.20, fully compressed.
If you have .595 lift and assume the spring won't perform past 1.15, then you're looking at an install height of 1.745 or larger. (1.15 + .595 = 1.745).
Thomas.
Ok my 987's are set at 1.800 right now, so if I drop the 918s and set them at 1.800 and the bind at 1.150 that will give me .650 from open till coil bind, which is a little tight but doable as optimum would be .655 (.595+.060 clearance at full lift) Is my math here correct or am I completeley missing something here? I though comp figured a .060 clearance when giving what the spring was rated at lift wise??? Looking at the chart comp gives the 918's have a larger range that the 987's, now I am confused. It shows install height up to 1.850 for both and the 987 coil binding at 1.200 while the 918's go to 1.15. I had my heads cut for the springs when I put them on and I know for a fact @ 1.800 we had lift plus .060 me and the machinist were doing the math and tried several different springs to see what would work best. He had a set of crane beehives that we tried but they wouldn't take the lift.
For Josh I don't see how the 918's would be a problem at 600 lift or less, do you have a link to your kaboom thread??
Old Feb 17, 2006 | 03:06 AM
  #19
Wckd94Z's Avatar
truedualws6 has a thread on beehives with all the part numbers, installed heights, etc. do a search that's what I went off of when I set mine up. lol i'd still be clueless about them if I hadn't used the SEARCH.
Old Feb 17, 2006 | 10:10 AM
  #20
SStrokerAce's Avatar
The problem is they don't drop in and measure the same installed height. Different retainers change the installed height a ton.
Bret
Old Feb 17, 2006 | 02:20 PM
  #21
95ttoplt1's Avatar
Ok so can some one give me the idiot proof package of part nuimbers I will need to convert from 987 to 918s?
Old Feb 18, 2006 | 09:35 AM
  #22
Originally Posted by truedualws6
Just as you stated. Use the Comp spring seats and 10* retainers with the
+.050" super locks and you should be in the 1.75" installed height range
with a stock head. Here are th PNs:
795-16 steel retainers,
614-16 locks (+.050)
4705-16 spring seats
I would think this setup is safe to .560" lift with just about any off the
shelf hyd roller you can throw at it. Maybe Bret can chime in with a bit
more detail on this.
That was done already.... I don't wanna say it but was that not idiot proof for ya? ;-)
Bret
Old Feb 18, 2006 | 12:40 PM
  #23
95ttoplt1's Avatar
Bret
Sorry I though that was just for stock heads. I am just making sure that will work with heads that have been machined for the larger springs, thanks for the help.
Noenav
Mar 1, 2019 07:38 AM
Red_94Formula
Jan 22, 2015 12:17 AM
Louey
Pacific
Dec 25, 2014 03:27 AM
Louey
Pacific
Nov 28, 2014 03:46 AM
GA93FORMULA
Jul 24, 2002 11:38 PM
