9 engine codes....
Old Jul 14, 2006 | 08:23 PM
bldjello's Avatar
9 engine codes....
I took it in to the shop today, to get a nail out of my tire, and to see if they could give me an estimate on how much it would cost to fix whatevers wrong with it and it turns out that i have 9 different "codes" comming up including-
21
22
86
62
63
66
57
58
33
does anyone know where i can find a list that will discribe what the code numbers mean? or does anyone know? the guy at the shop told me to take the car to a dealer. but i want to get an idea of what im getting into.
thanks
Old Jul 14, 2006 | 10:01 PM
Re: 9 engine codes....
Click the "DTCs" link in my sig.
I would bet that many of those are old, stored codes. Your PCM probably needs to be reset, so that you can see what trouble might be current.
Old Jul 15, 2006 | 06:06 AM
Guest47904's Avatar
Guest
Usually a high number of un-related codes are due to a faulty alternator. This is allowing the battery voltage to go below threshold at the PCM.
After you clear all the codes, if you can see what the ign voltage is as reported by the PCM while your scanning it.
Measure the voltage at the battery while it's running to be sure it is at least 14 volts.
Old Jul 15, 2006 | 09:39 AM
The interesting thing is the at least 3 of those codes (57, 62, 86) are not on any lists that I have seen for the LT1.
willismoons
Feb 14, 2015 08:42 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
centric
Aug 15, 2002 09:04 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
