8th digit in your vin??
Subscribe
May 22, 2008 | 12:15 AM
I have a 97 Z28 but I was looking at a 96 Z28 owners manual and it says that if your 5.7 doesn't have the letter "P" you can use 87 octane gas but if it contains the letter "P" you have to use 91 octane or higher. My car has the letter "p" on the 8th digit on my VIN. What is so special about the " P" on certain LT1's. Is it the timing or compression that was changed?
Reply
May 22, 2008 | 12:22 AM
Perhaps it is the knock sensor sensativity
Reply
May 22, 2008 | 12:27 AM
Why would GM put a higher knock sensor on certain LT1 motors?
Reply
May 22, 2008 | 01:09 AM
I think it would be for B-Body LT1s that have a lower compression, so they can use 87 octane.
Reply
May 22, 2008 | 05:27 AM
The 8th position of the VIN indicates the engine. "P" is the code for all LT1/V8 engines. There is no other code used for an LT1. "S" is used for the 3.4L V6, and "K" is used for the 3.8L V6. There is nothing "special" and there are no differences with "P".... they are all LT1's.
Reply
May 22, 2008 | 07:00 AM
Your owner's manual is a Camaro (not Z28 manual). When they say "P", they mean LT1 (as Injuneer noted).
Reply
Subscribe
