85 mph vibration????
Old Jun 19, 2003 | 12:42 AM
Xride's Avatar
I have a Vibration that starts at about 85 MPH, its not my tires, they ahve been balanced more times then I can count and ride perfect up untill about that speed.
It gets worse the faster I go, and by the time I hit 100 it feels like my car is going to shake apart.
Old Jun 19, 2003 | 02:07 AM
Blue89Bird's Avatar
prob the driveshaft unbalanced. try rotating it 180 degrees, if it doesn't work, get an LS1 aluminum shaft.
Old Jun 19, 2003 | 02:17 AM
revtime's Avatar
I am willing to bet it is your DS. I had the same problem and when I swapped it out with the 1LE all my bad vibrations went away.
Old Jun 19, 2003 | 04:21 AM
SilvercamZ28's Avatar
Definately your DS.. rotate it 180 nd see if it works.. probably wont I'd start looking for a replacement.....
Old Jun 19, 2003 | 04:24 AM
Blue96z28's Avatar
does the rotating it actually work?
Old Jun 19, 2003 | 04:30 AM
camaronutt's Avatar
what exactly do you guys mean by rotating the DS 180*? To put teh back in the front and front in the back??
Old Jun 19, 2003 | 04:58 AM
revtime's Avatar
You can take the shaft out of the rear yolk and spin it 180 and reinstall it. The rear U joint will fit both ways.
Sometimes this helps, sometimes not.
Old Jun 19, 2003 | 07:31 AM
Xride's Avatar
Thanks, I kinda thought it was me DS. I havent looked under my car, how do I take it apart? or is it pretty simple?
Old Jun 19, 2003 | 07:59 AM
This is a real simple process to accomplish...
1st... Jack up car
2nd.... I like to make a kark from my u-joint to the yolk (with a marker) to make sure I turn it over 180 incase I get interupted and have to stop...Take your (8mm?) wrench and take the u-boldt that connect the rear u-Joint to the rear yolk. You may have to pry them appart gently to get them to come appart.
3rd.... Remove DS and then re-install so that the marks are on oppisite sides of each other.... ie.. flipping it 180...
4th re-install u-bolts then lower car and then hit the highway to see if it stops the vibe... this works sometimes... but not always but it's worth a shot...
Good Luck
Old Jun 19, 2003 | 08:01 AM
1st... Jack up car
2nd.... I like to make a mark from my u-joint to the yolk (with a marker) to make sure I turn it over 180 incase I get interupted and have to stop...Take your (8mm?) wrench and take the u-bolt that connect the rear u-Joint to the rear yolk off. You may have to pry them appart gently to get them to come appart.
4th.... re-install u-bolts then lower car and then hit the highway to see if it stops the vibe... this works sometimes... but not always but it's worth a shot...
Good Luck
95chwagon
Oct 16, 2015 12:24 PM
4586
Sep 27, 2015 01:55 PM
autoxr166
Sep 25, 2015 04:21 PM
NewsBot
Sep 14, 2015 09:20 AM
mmf_1013
Sep 12, 2015 08:56 PM
