85 mph vibration????
I have a Vibration that starts at about 85 MPH, its not my tires, they ahve been balanced more times then I can count and ride perfect up untill about that speed.
It gets worse the faster I go, and by the time I hit 100 it feels like my car is going to shake apart.
This is a real simple process to accomplish...
1st... Jack up car
2nd.... I like to make a kark from my u-joint to the yolk (with a marker) to make sure I turn it over 180 incase I get interupted and have to stop...Take your (8mm?) wrench and take the u-boldt that connect the rear u-Joint to the rear yolk. You may have to pry them appart gently to get them to come appart.
3rd.... Remove DS and then re-install so that the marks are on oppisite sides of each other.... ie.. flipping it 180...
4th re-install u-bolts then lower car and then hit the highway to see if it stops the vibe... this works sometimes... but not always but it's worth a shot...
Good Luck
1st... Jack up car
Good Luck
1st... Jack up car
2nd.... I like to make a mark from my u-joint to the yolk (with a marker) to make sure I turn it over 180 incase I get interupted and have to stop...Take your (8mm?) wrench and take the u-bolt that connect the rear u-Joint to the rear yolk off. You may have to pry them appart gently to get them to come appart.
4th.... re-install u-bolts then lower car and then hit the highway to see if it stops the vibe... this works sometimes... but not always but it's worth a shot...
Good Luck
1st... Jack up car
Good Luck
autoxr166
Sep 25, 2015 04:21 PM
NewsBot
Sep 14, 2015 09:20 AM
