83 Camaro, want to install 95 Caprice LT1
Old Mar 23, 2013 | 10:55 AM
Strick's Avatar
I have a 83 Camaro 5 speed with the 305 which is trashed. I also have a 95 Chevy Caprice Classic that has a LT1. I'd like to install the LT1 in the Camaro. My only stumbling block would be the ECM and all the wiring required. My plan is to use everything in the Caprice (electronics) to run the LT1. Has anyone done this? If so, I could use a little help and or advice. A Helms Shop manual for the Caprice would really help out as I already have the FSM for the Camaro.
This could be a fun project. Thanks for any help.
Old Mar 23, 2013 | 12:07 PM
Re: 83 Camaro, want to install 95 Caprice LT1
LT1swap.com has a lot of info that might help you. When putting a computer controlled FI engine into an earlier car, it's all about the same.
Old Mar 23, 2013 | 06:49 PM
chevyowner02's Avatar
Common LT1 Swap Questions And Answers - Third Generation F-Body Message Boards
Should answer a lot of questions you will have.
Old Apr 20, 2013 | 06:43 AM
Strick's Avatar
Originally Posted by chevyowner02
Nobody seems to answer there. I guess this type of engine swap is history. Oh well.
Old Apr 20, 2013 | 11:47 AM
Post #1 in that 3rd Gen link has numerous links to threads with "answers". Did you not find the info you need in there?
Then there's this thread right here on the 3rd Gen forum:
https://www.camaroz28.com/forums/3rd...ite-up-474185/
At the bottom of that thread, you will see a list of related threads.
hotrodyou1
Dec 20, 2014 10:05 PM
Dec 4, 2014 11:56 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
Chrisdude
Jul 24, 2002 02:25 PM
