7th optispark installed. High RPM miss still present!!!!
Old Sep 24, 2006 | 04:34 PM
  #16
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Re: 7th optispark installed. High RPM miss still present!!!!
Originally Posted by blackztpi
well, you've proven its not the opti. we all try and replace a few things here and there rather than paying to be diagnosed, but Damn son! get it diagnosed
Its been to 3 shops and none of them can tell me anything I HATE LT1 IGNITIONS!!!!!!!!!!!!
But, I am going to replace the ignition control module, the computer, and get it retuned. If that doesn't fix it then I'm parting out the engine and doing an LS1 swap.
Old Sep 24, 2006 | 05:34 PM
  #17
Severous01's Avatar
Originally Posted by Injuneer
What part of the Opti is limited to 6,400rpm? The optical sensor has been proven reliable to over 8,000rpm. I run a 7,400rpm redline, using only the sensor. There was a guy who used to post here with the screen name DragBear who routinely and reliably ran his complete Opti high into the 7,000's.
just the fact that so much ionized air and humidity build inside it with that much rpm. especially on the non-vented units. and adding a high power coil adds to it, like MSD or 300+ modules. plus the coil is limited in how much spark can be attained from just one coil. it doesnt have time to fully charge before discharge. i dont remember where i saw it but i know i did...which is one of the reasons why i bought the ltcc setup in the first place.
also, i'm not saying that the opti isnt capable, just the majority of them arent. there are a few freaks out there...like some said about my 14 flat bone stock with a paper air filter wasnt possible...i did it and i know i did.
with rotor removed you remove everything bad about the opti. you remove the ionized air, you remove the crappy coil that loses discharge capacity at high rpm, you remove all the misfire issues when there's high humidity or water involved, and you remove the fact that there's only one coil vs 4 or 8.
Old Oct 3, 2006 | 09:40 PM
  #18
ShowStopper540's Avatar
if you get rid the the LT1, PM me and let me know a decent price, and you may have a home for it
Old Oct 4, 2006 | 07:28 AM
  #19
Javier97Z28's Avatar
Moderator
Check your dowel pin length on that hotcam?
Old Oct 4, 2006 | 10:06 AM
  #20
T/A-Bob's Avatar
Bad ground connections can cause all sorts of gremlins. I would disassemble the stack of ground lugs on the stud on the passenger side wheel well, and clean each one. Also, remove the stud and clean that. If this doesn't solve the problem, at least you've removed one possible cause (and it doesn't cost anything).
Also, perhaps you already did this... go to a shop that has the ability to scope your ignition. This will give you a complete diagnostic of the high-voltage portion of your ignition, including the individual plugs, wires, etc, everything. You can probably get this done for $50 - $75.
If these two ideas don't turn up anything, then I think chasing thru the steps in the factory manual is probably the best bet.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
1996LT1Z28
Mar 8, 2015 08:16 PM
jasonduaine
Mar 7, 2015 09:44 AM
DetroitZ28
Feb 13, 2015 07:33 AM
