7th optispark installed. High RPM miss still present!!!!
From: Austin, TX or Texas State University at San Marcos
Re: 7th optispark installed. High RPM miss still present!!!!
Originally Posted by blackztpi
well, you've proven its not the opti.
we all try and replace a few things here and there rather than paying to be diagnosed, but Damn son! get it diagnosed
I HATE LT1 IGNITIONS!!!!!!!!!!!!But, I am going to replace the ignition control module, the computer, and get it retuned. If that doesn't fix it then I'm parting out the engine and doing an LS1 swap.
Originally Posted by Injuneer
What part of the Opti is limited to 6,400rpm? The optical sensor has been proven reliable to over 8,000rpm. I run a 7,400rpm redline, using only the sensor. There was a guy who used to post here with the screen name DragBear who routinely and reliably ran his complete Opti high into the 7,000's.
also, i'm not saying that the opti isnt capable, just the majority of them arent. there are a few freaks out there...like some said about my 14 flat bone stock with a paper air filter wasnt possible...i did it and i know i did.
with rotor removed you remove everything bad about the opti. you remove the ionized air, you remove the crappy coil that loses discharge capacity at high rpm, you remove all the misfire issues when there's high humidity or water involved, and you remove the fact that there's only one coil vs 4 or 8.
Bad ground connections can cause all sorts of gremlins. I would disassemble the stack of ground lugs on the stud on the passenger side wheel well, and clean each one. Also, remove the stud and clean that. If this doesn't solve the problem, at least you've removed one possible cause (and it doesn't cost anything).
Also, perhaps you already did this... go to a shop that has the ability to scope your ignition. This will give you a complete diagnostic of the high-voltage portion of your ignition, including the individual plugs, wires, etc, everything. You can probably get this done for $50 - $75.
If these two ideas don't turn up anything, then I think chasing thru the steps in the factory manual is probably the best bet.
jasonduaine
Mar 7, 2015 09:44 AM
