7000 Rpm Lt1
Old Dec 6, 2003 | 08:57 PM
  #16
jasons93z's Avatar
Originally posted by 93formula
would be easier to drop in a ls1
Untrue, they cant rev that high either. In fact, many ls1 drivers that rev too high bend there push rods.
Old Dec 6, 2003 | 09:01 PM
  #17
JDBlaze85's Avatar
Ace_437
s*** it
thanx CamaroManiac and 93 Formula for the info.
Old Dec 6, 2003 | 09:26 PM
  #18
dnz28's Avatar
honeslty I have posted about this and even attempted planning a comb that would rev to around 8500, but here is the big but the lt1 is not the engine to be doing this with. The idea of a stroker is a good idea you can still rev it pretty high(6800). Well if you want to rev that high well your better of dropin in a sbc1 for the following reasons
lt1-in my opinion are design for low end torque and hp
lt1- heads will not flow at all at those rpms
lt1- cost of doing this because every piece would have to be custom would be upward of 15,000 or more.
lt1-opti will break faster then you can shove a thumb up your *** at those engine speeds.
lt1- computer like said earlier only goes to 7000rpms
now if you have to have this you can get always carb your lt1 and get rid of your computer but once again I can guarntee you will never pull power that high in the rpm range.
I not saying its not possible but not even lt4 heads would work
now if you got pockets that are deep you can convert a set of sbc 23* heads to the lt1 get billet everything, run a soild roller, carb it , but you basicly just converteed your lt1 to a standard sbc so gjust start with a standard sbc and do crazy those can rev to out rages numbers if done proper. do some research engines like that are 90% plannin and 10% actual labor.
well I think I said enough.
Old Dec 6, 2003 | 09:34 PM
  #19
JDBlaze85's Avatar
great post dnz28
you've convinced me. Im better off going with an old school block. I have alot of experience with them and the market is wide open for those blocks. couple of questions:
So I can rev a stroker to 6800? I got everything to put together a 383 sbc1.
Is the high revving mostly inside the cam and valvetrain?
what size lift would work for 6800?
If I go old school block.......how would my T-56 hook up with the flywheel. Can my tranny work with this block without using a cheesy adapter that would break?
Old Dec 6, 2003 | 09:41 PM
  #20
93formula's Avatar
that is not entirely true, there is a local with lt4 heads, ported by GTP and MTI, flow numbers were over 300. on the dyno his numbers were still climbing at 6800 when they had to stop the dyno, this is with a cc306 cam. so if yo find the right flowing heads it will work. the opti will not fall apart at 7 k either, it is better then the old sbc design. it was designed as a race type ignition. and it will not cost upwards or 15k for a motor that revs that high unless you want to pay for it. i could build one for well under 5 if i wanted to.
Old Dec 6, 2003 | 09:43 PM
  #21
93formula's Avatar
the t56 will bolt up to a sbc, but your gonna have problems with the top mount distributor up in the cowl. in a 4th gen your better off with a lt1, if it were a 3rd gen then go right ahead.
Old Dec 6, 2003 | 09:44 PM
  #22
Larnach's Avatar
You could rev a 421 to 8000rpm if you wanted to, piston speed averages nowaday's has gone up a bit since a while back.
The fact of the matter is, any engine combo will rev to 7000, it won't exactly make a lot of power but it will rev to that.
If you want to do it "cheaply" to 7000rpm, make ****loads of power do the following.
Get a set of AFR 220 heads, have them ported, get a big solid roller cam, run a billet crank, titanium/billet rods, and forged pistons and be done with it.
Or you can be smart, since you aren't racing in any class restricting your mods obviously, go with forced induction. Have a stout short block, port the stock heads, run a conservative FI cam and supercharge it. Make 800rwhp with $10,000 instead of making 500rwhp with $20,000.
Old Dec 6, 2003 | 09:47 PM
  #23
JDBlaze85's Avatar
the distributor up on top is no problem at all. We've done one already with minor cutting under the dash. Didnt have to drop the engine of nothin major either. took about 30 minutes. distributor comes in and out like butter.
As for the optispark dist.
If you just look at that thing the wrong way, it falls apart.
I've only seen them fail about a million times.
T-56- yeah Im pretty sure it will bolt up.........but I think the flywheel is smaller on the LT1 so there lies a problem.
Old Dec 6, 2003 | 09:53 PM
  #24
Larnach's Avatar
If your going to go through all the trouble to adopt a Gen 1 engine, you mind as well adopt the flywheel to the 153 tooth design. Tilton has a kit for it.
Old Dec 6, 2003 | 09:56 PM
  #25
JDBlaze85's Avatar
do they have a website or somethin?
Old Dec 6, 2003 | 10:00 PM
  #26
Larnach's Avatar
I dunno, try Tilton.com or something, search for something.
You have heard of Tilton haven't you?
Old Dec 6, 2003 | 10:11 PM
  #27
JDBlaze85's Avatar
yes
Old Dec 6, 2003 | 10:42 PM
  #28
dnz28's Avatar
why do you never see a hardcore lt1 drag car, because most have switched over to the old sbc design.
As for you coments on the heads 300 cfms is nice but I believe you need way more to accomplish anything above 7500rpms but maybe thats just my opinon. take a look at the advanted tech section if you want mucho power most have standard sbc heads convertered to fit the lt1 block. lt4 are nice but just dont cut it. look at lt1/lt4 na numbers compared to a sbc1. sbc1 dominate.
  #29
jasons93z's Avatar
If you build up a 383 you should have no problem depending on cam size. If it were me i would shift at 6600k or so, no higher.
Old Dec 6, 2003 | 10:45 PM
  #30
jasons93z's Avatar
Actually, i think you are wrong my friend. Jordan Musser revs his high and runs low 9's. BTW, he is still using the original opti with no problems.
