7 quarts too much for canton 242-T pan?
Old Jan 12, 2010 | 10:58 AM
LT1PoloGreenSS's Avatar
I just noticed I put 7 quarts in my new Canton pan and it calls for 6. Is that going to do any damage?
Old Jan 12, 2010 | 11:12 AM
RamAir95TA's Avatar
What does the dipstick say? Is the filter full?
Old Jan 12, 2010 | 02:09 PM
Bersaglieri's Avatar
Guys have had oil pressure problems over filling their aftermarket pans. Javier is the one who ended up running 5.5 quarts in his Milodon 30909 pan if I remember correctly. If I were you I'd get a mechanical oil pressure gauge and watch the pressure on a few WOT runs. Make your adjustments based on that.
-Dustin-
Old Jan 13, 2010 | 11:22 AM
97WS6Pilot's Avatar
I never used more than 6 qts with my Canton pan. If I did it would use oil. So I'm assuming it was burning it. The stock dipstick should read one qt low when you put 6 qts (full) in because the oil sits lower. I didn't add any oil until it showed 2 qts low on the factory dipstick.
RUENUF
Mar 13, 2016 03:37 PM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
wbspoon
Sep 19, 2015 08:12 AM
1slow93z28
Sep 1, 2015 06:22 PM
