7 dtc codes
Old Oct 12, 2009 | 09:40 AM
JC95Z's Avatar
7 dtc codes
Finally figured out how to check my ses light. Came up with seven codes 027,032,036,045,048,065,066. I deleted the egr valve just need to get it tuned out, I'm trying to figure out my problem when it rains which i imagine is the 036. My opti harness is spliced together and too short due to trying to use a non vented opti when i put my new engine in so im going to fix that and see if that helps.What im wondering about is 048 the mass air flow circuit problem? The screen is removed from it,will this cause this?
Old Oct 12, 2009 | 10:44 AM
meissen's Avatar
27 - EGR solenoid circuit
32 - EGR recirculation
36 - OptiSpark high resolution signal faulty
45 - Bank 1 (left) O2 sensor, rich
48 - MAF sensor circuit
65 - Bank 2 (right) O2 sensor, rich
66 - A/C refrigerant pressure sensor circuit, open or shorted
For specifically the 48:
http://www.mifbody.com/DTCs/DTC 48.jpg
http://www.mifbody.com/DTCs/DTC 48_2.jpg
95z_28_camaro_4_Ivan
28
Jul 23, 2015 11:55 AM
timmy39120
May 8, 2015 11:41 AM
dreamer1q
Aug 20, 2002 11:19 AM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
