7/16" studs for Comp Cams Pro Mag
Old Aug 12, 2004 | 09:57 AM
"White Knight"'s Avatar
What needs to be done to use 7/16" studs with the Comp Cams Pro Mag? It says simple 15min thing with no machining. Is it just threaded like a 5/8's? What i am wondering is what you do in that 15 minutes? Make clearance on the valve covers?
Old Aug 12, 2004 | 10:01 AM
BadAssed93Z's Avatar
Re: 7/16" studs for Comp Cams Pro Mag
im pretty sure that they both have the same size base for the studs so you just replace the factory ones and stick on the 7/16" ones. but i havent installed mine yet so im not sure.
Old Aug 12, 2004 | 10:04 AM
WS Sick's Avatar
Yep the 3/8s studs and 7/16s studs both have the same base size, the upper stud is where the difference is at. No machining is necessary, you just need rockers with the right sized hole and poly locks.
Old Aug 12, 2004 | 10:57 PM
Bud M's Avatar
Yeah, its just a metter of unscrewing the stockers and screwing the 7/16s in along with your guideplates if you are going NSA. 55 ft lbs if I remember right.
Old Aug 13, 2004 | 08:22 AM
Thanks guys that's what i needed.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
HarleyZ28
Oct 5, 2015 06:23 AM
MadMav
May 25, 2015 09:35 PM
alliance12364
Mar 6, 2015 04:39 PM
