7/16 Pro-Mags and stock valve covers?I
Old Jun 24, 2004 | 10:52 AM
Z-RATED94's Avatar
I searched for over an hour and could not find an answer. Could someone please tell me if the 7/16 Pro Mags will fit under the stock valve covers with a little trimming. If not, do you know where I might find a set that looks half way decent and isn't to pricey. I realize the alt. will need a little grinding to clear anything thats taller than stock. Thanks for any help.
Old Jun 24, 2004 | 10:57 AM
Shawn 97 Z28 M6's Avatar
Texas Moderator (1998-2009)
They fit.. And you don't have to trim the center bolt supports.... That's only askiing for a leak. Just flatten them w/ a pair of vice grips and twist them so they run parrallel w/ the supports holes. They'll slide right between the RR's when you do this.
Old Jun 24, 2004 | 11:01 AM
Red96Lt1's Avatar
What would you get, SA or non SA rockers. I think the 7/16 are only available in the non SA.
Old Jun 24, 2004 | 11:09 AM
Non S/A.. They give you "room to grow" in the future.... Until a person would switch to shaft mount at least
Old Jun 24, 2004 | 11:10 AM
Z-RATED94's Avatar
Red96Lt1, If your asking me, I went with the 7/16's NSA RR's because that's what Bret Bauer recommended. Didn't even know you couldn't get them as a SA rocker.
Shawn, thanks for the quick reply, and I know if your wrong you'll chip in for a set of valve covers, right?
Old Jun 24, 2004 | 11:22 AM
LOL.. I'm not wrong .. I've done this to a bunch of sets... Just make sure that you line up the valve cover bolt hole.
HectorM52
Jul 30, 2017 11:46 AM
Roadie
Feb 16, 2015 10:34 AM
HectorM52
Jan 30, 2015 11:34 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
