7/16 Pro-Mags and stock valve covers?I
I searched for over an hour and could not find an answer. Could someone please tell me if the 7/16 Pro Mags will fit under the stock valve covers with a little trimming. If not, do you know where I might find a set that looks half way decent and isn't to pricey. I realize the alt. will need a little grinding to clear anything thats taller than stock. Thanks for any help.
They fit.. And you don't have to trim the center bolt supports.... That's only askiing for a leak. Just flatten them w/ a pair of vice grips and twist them so they run parrallel w/ the supports holes. They'll slide right between the RR's when you do this.
Red96Lt1, If your asking me, I went with the 7/16's NSA RR's because that's what Bret Bauer recommended. Didn't even know you couldn't get them as a SA rocker.
Shawn, thanks for the quick reply, and I know if your wrong you'll chip in for a set of valve covers, right?
