6.0" Rods, any clearance issues?
Old Nov 17, 2006 | 07:38 AM
Vicious95Z28's Avatar
Got a factory crank and using 6" rods. Any grinding needed? I know I need pistons for 6" rods.
Old Nov 17, 2006 | 08:45 AM
CrazyLT1's Avatar
No grinding is needed, your clearance will be fine. Just make sure you get pistons made for 6" rods.
Old Nov 17, 2006 | 08:56 AM
Javier97Z28's Avatar
Moderator
No grinding needed.
Old Nov 17, 2006 | 09:04 AM
ulakovic22's Avatar
No grinding to the block, but you might have problems with the stock windage tray. I now I did and probably a few others too.
Old Nov 18, 2006 | 02:35 PM
Severous01's Avatar
i had issues...i got a 383 though.
Old Nov 20, 2006 | 10:39 AM
Stuck one in the other day just to check the windage tray, no problems
Old Nov 20, 2006 | 04:04 PM
tireburnin's Avatar
I have 6.0 rods with L19 bolts. The block had to be clearenced to allow for the bolts. They are big bolts.
camaro98_speed
Wheels and Tires
Mar 17, 2015 07:36 AM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Bill'sWS6
Aug 5, 2002 01:00 PM
