5k rpm stumble FIXED!!!
Old May 4, 2003 | 08:57 PM
MJ_Z28's Avatar
well, after 3 hours on the very front passenger plug and 45 mins to do all other plugs and wires , a new coil, coil wire, an lt4 KM , and most importantly some fresh heat transfer grease in the coil assembly, my 5k rpm stumble/miss/hickup is FINALLY fixed. I think it boiled down to the coil and coil wire mostly (they were pretty fried) and also once i got the old plugs out, lots were gapped way too large...
While i was under there i found and fixed a massive exhaust leak and a bolt was missing from the gear cover thing on the back axle (I'm a mechanic moron...but I'm learning).
Hope this helps some of you out there w/ the 5k rpm problem...i'm so much happier w/ my car now!
-mj
Old May 4, 2003 | 11:17 PM
cm95z's Avatar
i had a high rpm stumble a few months ago also. like yours, my coil and coil wire were real corroded. i pissed me off so bad, but once i got it fixed, it was like night and day. it's nice to have a smooth running car again!
Old May 4, 2003 | 11:19 PM
chasmanz28's Avatar
always good to hear a good running Lt1 on here
Old May 4, 2003 | 11:20 PM
KeVMaN's Avatar
mine was the coil wire. god its nice to have your car rev to 6000 and light up the tires on the 1-2 shift. mmmm
Brake_L8
Jan 20, 2015 09:44 AM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
Dyoung_Z28
Nov 25, 2014 05:26 PM
MislMan
Jul 19, 2002 11:41 AM
