58mm Throttle Body Debate
Old Dec 31, 2009 | 12:31 PM
  #16
1989TransAm's Avatar
"Also Lloyd recommends a monoblade TB on his LE3"
There has been more than one dyno test that has born out Lloyd's recommendation. Especially with the LT1 intake.
Just a thought, but would not a mono-blade throttle body effectively increase the plenum size at wide open throttle? You have one big gaping hole at the throttle body.
Old Dec 31, 2009 | 01:09 PM
  #17
ZDriver96's Avatar
well this subject is pretty hot.. because I have several experienced LT1 owners saying I'll gain 10-20rwhp and several others saying I'll lose HP....
Can't wait to see.
Also in fairness to the LE2 package, remember I ran it with the Borla Restrictor plate making my right exhaust pipe about the size of a half dollar.
I'm taking it out after my TB test so we will see what the dyno #'s are with that as well.
Old Dec 31, 2009 | 02:15 PM
  #18
Over time I have went from a 48mm, 52mm, 58mm and now a mono-blade. At no time did I loose power going to a larger throttle body. The idea is at wide open throttle to keep the plenum as close to atmospheric pressure as posible. The larger the throttl body the better chance of that happening. Having one "too big" will not hurt a thing.
Old Dec 31, 2009 | 02:23 PM
  #19
dangalla's Avatar
except for that throttle response thing
Old Dec 31, 2009 | 04:49 PM
  #20
coco95z28's Avatar
i just put on a 52mm summit brand throttlebody on my car. didnt notice any negitive effects but my air filter/intake got twice as loud. you can really hear it hiss over the motor. (just by switching)
i did notice that the throttle responce got much better. it snaps now, not that slight hesitation when your in neutral and tap the gas sort of thing. (at least mine did a little)
Old Dec 31, 2009 | 05:45 PM
  #21
96capricemgr's Avatar
With port injection a "too big" throttle body just acts as an on/off switch, it does not "hurt" throttle response by making it lazy like too big a carb will.
Old Dec 31, 2009 | 06:13 PM
  #22
"except for that throttle response thing"
One would think so and I sure did, but in reality it is not bad at all. Maybe my Yank SS3600 Stall helps.
Old Mar 17, 2010 | 09:02 PM
  #23
jrutland's Avatar
Any update on this?
Jerry
Old Mar 17, 2010 | 10:03 PM
  #24
ZDriver96 posted his dyno test results 2 weeks ago:
https://www.camaroz28.com/forums/sho...highlight=58mm
Old Mar 17, 2010 | 10:14 PM
  #25
jrutland's Avatar
Thanks!
Potent77
Mar 16, 2022 12:13 AM
Peytons'z
May 6, 2021 09:25 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
kaoticcamaross
Feb 17, 2015 03:13 PM
