58 or 52 mm TB?
Old Feb 15, 2006 | 04:12 AM
jonesy's Avatar
58 or 52 mm TB?
rebiulding to 355 and doing some mods, ported heads w/ 2.02/1.6,306 cam, Hooker long tubes 30 lb inj,and cai along with tune, was wondering what tb to use . I don't ( at this time ) plan on adding NOS, is the 52 sufficient?
Old Feb 15, 2006 | 06:02 AM
Jameslt1TA's Avatar
Re: 58 or 52 mm TB?
Go for the 58...imo the 52 is pointless. You probably wouldnt notice much gain over stock with the 52.
Old Feb 15, 2006 | 09:28 AM
OBE1 95Z28's Avatar
Re: 58 or 52 mm TB?
The intake will need to be ported to run the 58mm TB.
Old Feb 15, 2006 | 11:20 AM
RE AND CHERYL's Avatar
Re: 58 or 52 mm TB?
It's up to you but your setup will never come close to out flowing a 52mm TB. The stocker flows about 650CFM and a 52mm will flow about 750-775CFM. Most people go too big in this area.
Old Feb 15, 2006 | 11:30 AM
blkchevyz's Avatar
Re: 58 or 52 mm TB?
if you have your intake off just go for the 58
i did a swap on a 330 hp car on the dyno from a stock to 58 and it gained 10 hp all the way up the rpm band.
the intake was already ported for the 58
really your not going to run into loosing velocity with it so you really cant go too big.
Old Feb 15, 2006 | 12:48 PM
Z28LT1_Just_Nasty's Avatar
Re: 58 or 52 mm TB?
If you have the intake to match it go 58mm
Old Feb 15, 2006 | 01:48 PM
96m6lt1's Avatar
Re: 58 or 52 mm TB?
as long as your intake is modded at the mouth go for the 58mm your engine can only ingest as much air as it needs weather you have a 52 or 58,going to a 58 also allows you to expand later rather than to try and sell old to move up.
Old Feb 19, 2006 | 03:45 PM
jonesy's Avatar
Re: 58 or 52 mm TB?
thx 4 replys
Old Feb 19, 2006 | 04:01 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Re: 58 or 52 mm TB?
What does a stock MAF flow? Because can't your TB only flow what your MAF flows? I have been looking into upgrading my TB too but was wondering if it was pointless if the MAF was still holding me back...
Old Feb 19, 2006 | 06:14 PM
LameRandomName's Avatar
Re: 58 or 52 mm TB?
Originally Posted by blkchevyz
if you have your intake off just go for the 58.
That's probably the best thing to do. If you have the intake off anyway and you have yet to buy either a 52 or 58, then you might as well go for the 58.
Keep in mind that a tune will be needed and the trittle tip-in may be a bit abrupt for your taste, but since it's port fuel injected you don't need to worry about vacuum signal like you do with a carb.
