Anyone see Comp r's not pull past 6000 rpm?
Old Feb 18, 2006 | 07:30 PM
94 guy's Avatar
i dynoed the other day and my motor would not pull past 6200 and then it would fall flat on it's face. the guy doing the dyno tune was alan futral he said he has seen another car do the same and they switched lifters and the car pull to 6700 no problem.i have the GM846 in a 355.
Old Feb 18, 2006 | 07:42 PM
MachinistOne's Avatar
Re: Anyone see Comp r's not pull past 6000 rpm?
There are many reasons why that could happen, my first idea would not be lifters...volumeric efficiency problem(restricted exhaust or intake), tune problem, valve float...etc
What springs and installed height do you have? Pressures? Tune? What exhaust?
Help us out with some specs on the motor.
Old Feb 19, 2006 | 02:21 PM
marshall93z's Avatar
Damn those Comp R's!
Old Feb 19, 2006 | 02:40 PM
atljar's Avatar
What were they lashed at?
Old Feb 19, 2006 | 03:02 PM
turbo_Z's Avatar
Set the rockers and lock them down a hair past "0" lash... see if it improves.
Old Feb 19, 2006 | 04:48 PM
94 guy's Avatar
i have 150lbs on the seat and 395 open so i don't think it's float. they are set at 1/16 of a turn.
Old Feb 19, 2006 | 06:56 PM
That's a LOT of pressure on the open for a hydraulic roller...
MadMav
May 25, 2015 09:35 PM
carl.froehlich
Mar 13, 2015 12:38 AM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
