.568 lift to much for daily driver?
just picked up a custom cam and it's got .568 lift with 1.6rr and .528 with 1.5
I'm currently running the hotcam with my 1.6 rr and i was thinking of swapping to 1.5 because I'm afraid of breaking a spring at that much lift on a daily driven car.
Any opinions?? experiences?
edit: i will be running 918 springs
Re: .568 lift to much for daily driver?
Originally Posted by jsetzer
No, it will be just fine.
I have .595 on my daily driver, and a friends is like .635. Nothing wrong with it.
Originally Posted by luckyou03
so your running .595 on .600 max lift cm612 springs?
Soon to be on some different springs though. These did their job, but wore out really quick.
I know of a motor with .630ish lift on some .550 springs. More to springs than their "recommended" lift.
it will work....sttick that sucker in and Let us know if you like that cam IE:drives well and makes good power...Im still running a hot cam .....me likes
.568" here also...Probably the same or similar to Myzb383's. No problems at all. As long as the supporting valve train can handle it, you're fine. These days .568" isn't at all that big...
--Alan
--Alan
