52mm TB on stock motor
Old Mar 2, 2003 | 06:30 PM
Haskin Z28's Avatar
i hear all the bad mouthing of installing a larger TB on a stock motor but does anyone have any dyno results? i want to find another fairly cheap bolt on
Old Mar 2, 2003 | 06:34 PM
blazzinbird's Avatar
tb's are cheap?????????
you will not see any diffrence from a 48 to 52 unless you have some head and cam work done...
Pandamonkey's Avatar
I've seen some dyno results a while back from this.
Not a good bang for buck on a stock motor.........
Get a nice cam kit for all it's worth.
Old Mar 2, 2003 | 06:46 PM
1fast95Z's Avatar
How about this, does anybody know the effect of a larger TB on a modified engine, such as a heads/cam/LT engine?
Old Mar 2, 2003 | 06:56 PM
dlx3200's Avatar
Thumbs up
I have a 52mm tb with some other bolt ons. It improved throttle response, I was happy with it but I also have a cam I'm going to add now.
Old Mar 2, 2003 | 07:05 PM
Euclid's Avatar
I'm not sure WTF all you people are talking about, a 52mm TB not making any difference on a stock motor???
In the big end, they feel like whole new cars!
You'll think you're doing 60 or so, look down and the speedometer is readin 90-95
Old Mar 2, 2003 | 07:10 PM
DubbyZ28Camaro's Avatar
A lot of people running 10's with the LT1 that I have heard of are still running the stock throttle body. It will flow well enough until you get into heads/cam, then I would upgrade, but on a stock motor, it is really a worthless mod.
Save your money for something else IMO...
Old Mar 2, 2003 | 07:12 PM
madwolf's Avatar
You must have gotten one that was lacking the airfoil. I put one with an airfoil on mine and drove it... thought I was doing 60 and when I looked I was really doing 120....
Just get a stall or something. Don't waste your money on a TB because all it's gonna do is screw up the way your tranny shifts. (make the shifts softer )
Old Mar 2, 2003 | 07:20 PM
Euclid's Avatar
makes it shift softer?
really?
Old Mar 2, 2003 | 07:22 PM
madwolf's Avatar
really?
On an A4, yes.
Old Mar 2, 2003 | 07:33 PM
Euclid's Avatar
how so?
Old Mar 2, 2003 | 08:42 PM
NOMAD's Avatar
Cool
My tb's have been on stock cars to 383's to 12 second beasts (Sideways_into_3rd). Noone has ever said they didn't notice an improvement. I've switched back and forth on my car several times (I'll usually sell one off it after i've run it awhile) and I do notice a difference. My car is far from stock though
-Shannon
Old Mar 2, 2003 | 08:48 PM
how so?
Actually your MAP sensor monitors manifold vacuum and in an electronically shifted tranny such as the 4L60E, the manifold vacuum is in correlation the load on the engine so in this case the MAP sensor will determine when the transmission changes gears. By changing to a bigger TB, you are changing the manifold vacuum.
Old Mar 2, 2003 | 08:49 PM
GUMP's Avatar
I know of at least one stock throttle body that has gone 10.2's (NA). Personally I have been 10.89 at 3300 lbs (NA).
Best Regards,
Daren
Old Mar 2, 2003 | 08:58 PM
Prorac1's Avatar
Dosent any one read car craft anymore? They just did one in their project Malibu. They did a maf and a THrotle body and gained a whoping................hold on to your hats kids.......................12 hp, for 700 dollars. I dont know about anyone else but that could buy a converter or cam kit. Just my .02 prorac1
