52 mm throttle body
Old Mar 31, 2006 | 11:55 AM
bodydroppeddually's Avatar
52 mm throttle body
would you have to port your intake for a 52mm throttle body?
Old Mar 31, 2006 | 11:57 AM
Colin91Z's Avatar
Re: 52 mm throttle body
No, the openings are already 52mm.
thanks
thanks
Old Mar 31, 2006 | 02:52 PM
OBE1 95Z28's Avatar
It's my understanding that the stock intake opening will support a 54mm TB.
Old Mar 31, 2006 | 03:30 PM
I measured my stock LT1 intake, and the bores are EXACTLY 52.00mm. There is a tiny chamfer at the front that is obvioulsy a larger diameter, but the full thickness of the bore behind that is 52mm.
Old Mar 31, 2006 | 03:40 PM
firebirdStud's Avatar
yup, im with fred. I had to open up the throttle when I installed it, so my 52mm TB lined up exactly with the bores, so I had a true 52mm opening at WOT. There is a little slack between all the bolt holes which adds up to a possible 2mm loss if not lined up perfectly.
Old Mar 31, 2006 | 04:06 PM
so a 52mm is the biggest that you can go with a stock intake?
Old Mar 31, 2006 | 04:10 PM
yup.
Old Mar 31, 2006 | 04:16 PM
You can bolt whatever you want on it, but the flow through anything larger than 52mm is not going to be very smooth. AS&M claims their 54mm TB will work, but that extra mm on each side would seem to leave a "lip". Does the added turbulance offset the gains from the larger TB bores?
Potent77
Mar 16, 2022 12:13 AM
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
warmeck
May 1, 2015 11:30 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
