5 Opti's in less than a year!!!!!
Old Oct 22, 2006 | 05:03 PM
Bill_Mitchell's Avatar
A friend of mine has a 95 M6 Z28 and has replaced the opti five times in less than a year. It appears as though the rotor is walking out toward the cap and has disintegrated. It rubs the ridges off the cap and seperates the metal part from the rotor. There is no play in the opti nor does the cam appear to be walking...Any suggestions?
He just bought a new Accel and it lasted two weeks. He's pulling it as I type this.
Thanks for the response
Old Oct 22, 2006 | 05:27 PM
Mtrhds94Z's Avatar
Re: 5 Opti's in less than a year!!!!!
2 things come to mind:
Make sure the cam dowel pin isn't too long..
Make sure the proper venting hoses/harness are used, [the harness has a restrictor in it], not full manifold vacuum to the opti..
Old Oct 22, 2006 | 06:41 PM
Dave89IROC's Avatar
agreed
can yoiu give us a few more details?
motor stock or modded(if modded, how?)
Old Oct 22, 2006 | 08:30 PM
That's all I know right now.
I'm studying this vacuum thing. I'll get in touch with him tomorrow and try to work on that. I'll try to get some pics of the damaged Opti's....he saved them all.
Bill Mitchell
Old Oct 23, 2006 | 08:16 PM
ChevalierSS's Avatar
This is what I was thinking too. 95 uses a long dowel pin cam. It's possible he has been usisng the pre-95 opti.
Old Oct 23, 2006 | 08:24 PM
RE AND CHERYL's Avatar
They aren't interchangable at all.
Old Oct 23, 2006 | 09:48 PM
You did not indicate any mods, but if he has an aftermarket cam, chances are the dowel pin is too long. That will push the drive and rotor into the cap.
Old Oct 24, 2006 | 05:33 AM
Guest47904's Avatar
Guest
You would think after number 2 he would have ground it down even if he doesn't know how long it should be.
Old Oct 24, 2006 | 07:05 AM
Javier97Z28's Avatar
Moderator
Sounds like the dowel pin is too long....
Sergio
Jan 27, 2016 04:27 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
Injuneer
Dec 15, 2014 09:36 AM
thenewkid
Nov 27, 2014 09:41 AM
