5.7 to 6.0 rod
Old Aug 8, 2003 | 10:31 AM
POSSESSEDZ's Avatar
5.7 to 6.0 rod
I was wondering what benifits you get from the 6.0. than the 5.7.
Old Aug 8, 2003 | 10:34 AM
KCFormula's Avatar
From my understanding the 6.0 rod allows the piston to be at TDC longer which helps combustion.
Smokey Yunick always used to say "Put the longest rod you can, into your motor"
This has been discussed a lot in the advanced tech forum and my take from it all is...
-Forced induction use 5.875 rod because of piston skirt and ring lands
-NA motor use 6.0 or longer if you can fit it in there with the cam you use.
Old Aug 8, 2003 | 11:09 AM
Gripenfelter's Avatar
6.0" rods also mean less cylinder wall wear as well.
Old Aug 8, 2003 | 11:17 AM
rskrause's Avatar
Moderator
You really ought to try a search. This has been discussed extensively here.
Rich Krause
IndyZman
Oct 22, 2015 02:17 PM
karpetcm
Sep 29, 2015 10:08 AM
greenzee28
Sep 25, 2015 04:29 PM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
