is it a 5/16 pushrod??
Old Feb 13, 2007 | 01:26 AM
ZX636RIDER03's Avatar
Question is it a 5/16 pushrod??
wanted to replace my lifters and thought that it would be a good idea to change out the pushrods at the same time. can anyone tell me what the pushrod length is or what size to look for if i was looking to replace the stock ones with some hardened ones out of a summit catalog, the book has all these diffrent lengths and 5/16 and 3/8 which ones??
Old Feb 13, 2007 | 07:16 AM
2000GTP's Avatar
They are 5/16" in diameter.
Old Feb 13, 2007 | 09:04 AM
mzgp5x's Avatar
I think stock (97 LT1) are 7.2 inches. If you run a larger cam, check the tappet pattern (should run @ mid point on valve) for measurement of larger pushrods. I run .558" lift and went with a 7.3"
Old Feb 13, 2007 | 10:07 AM
2000GTP's Avatar
Yes, the stock length is 7.2 inches. The hardened stock replacements should run around 30 bucks.
Old Feb 13, 2007 | 10:49 AM
rskrause's Avatar
Moderator
There is no substitute for one of these if you are working on engines.
Old Feb 13, 2007 | 10:53 AM
Z-RATED94's Avatar
Just don't use the tape measure when checking bearing clearances. Found out the hard way.
13qtr
Oct 28, 2016 08:11 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
94Form
Jul 17, 2015 10:56 PM
