4bolt main ?....
Old Oct 3, 2011 | 10:10 AM
Lt1son's Avatar
4bolt main ?....
Well def going to ask a ? that i may get heat for... but i recently bought a lt1 out of a caprice and pulled pan and the 3 center caps were 4bolt and the outer thrust was 2bolt as well as the other end cap... this is considered 4bolt main block right? just confused cuz i thought 4bolts only came in vettes.. thanks guys.. and i did search just couldnt find ne pics.. thanks
Old Oct 3, 2011 | 10:14 AM
Queens94z28's Avatar
Re: 4bolt main ?....
You are correct. Its most likely a replacement LT1 block. All the replacement blocks were 4 bolt mains.
Old Oct 3, 2011 | 10:18 AM
Lt1son's Avatar
Thats great.. Thanks... Should be perfect for a build! Thanks again
Old Oct 4, 2011 | 01:33 PM
ZX636RIDER03's Avatar
Is it possible then that they made the 97 lt1 block in a 4 bolt? When I did the rebuild on my block i thought i recalled that the front and back caps were 4 bolt.
Old Oct 4, 2011 | 03:01 PM
ACE1252's Avatar
If was a 4-bolt from GM, I believe only the three center caps were 4 bolts.
Old Oct 4, 2011 | 04:15 PM
I take that back, its a 2 bolt. mis-read the intial post.
Old Oct 5, 2011 | 03:24 PM
Z28SORR's Avatar
This block has steel billet caps but still demonstrates what we're talking about.
Only the three center caps have 4 bolts.
http://i886.photobucket.com/albums/a...4/100_0032.jpg
Old Oct 5, 2011 | 05:26 PM
It's possible that 4-bolt main blocks were used in 97 F-Bodys. If they had any left over from the Corvette, which discontinued the LT1 in 1997, I'm sure they put them in whatever came down the production line.
RUENUF
Mar 13, 2016 03:37 PM
cocopops
Cars Wanted
Feb 1, 2016 06:22 PM
Ericksd
Jan 20, 2016 06:07 PM
heus
Sep 8, 2015 12:01 PM
carolinacasper
Jul 22, 2015 04:47 PM
