48mm vs 58mm track results inside
Old May 16, 2004 | 11:02 AM
  #16
Shawn 97 Z28 M6's Avatar
Texas Moderator (1998-2009)
"split BLM mod" ?? What's that?
Old May 16, 2004 | 11:46 AM
  #17
Myxtreme1's Avatar
Yeah what is that?
Old May 16, 2004 | 12:03 PM
  #18
Mikey97Z's Avatar
So what would be programmed differently for the bigger throttle body? (besides any idle air stuff)
Old May 16, 2004 | 12:09 PM
  #19
EviLZ28's Avatar
Here is the split BLM mod....
http://www.noid.org/~lj/PCM%20Tutorial/SplitBLMinfo.htm
Old May 16, 2004 | 12:10 PM
  #20
'94 Bad A Z28's Avatar
Originally posted by Nestromo
In no way does that make me want to shell out $350.
Thanks.
Old May 16, 2004 | 01:01 PM
  #21
Josh'95Z28conv's Avatar
I watched as a local ImpySS owner swapped out his stocker for a 58mm at a local dyno, and gained about 15rwhp. His a/f did change, and with further tuning he could have picked up some more. He's running a CC306 cam, and very high flowing heads. The only stock part of the top end of the engine was the TB.
Old May 16, 2004 | 01:53 PM
  #22
MyZb383's Avatar
It's not really that complicated.
If a 48mm opening will supply sufficient airflow that the stock TB is not the limiting factor in the engine's ability to make horsepower, a bigger one will not help.
But if the engine has big enough improvements to the cam/heads/exhaust that it can make use of more airflow than the stock 48mm TB can supply, changing to a larger one will make a difference.
How much difference will be determined by how much more airflow the engine can use.
It seems like people prefer a one-size-fits-all answer to these questions. There isn't one, usually.
Old May 16, 2004 | 08:50 PM
  #23
"White Knight"'s Avatar
You only go the 58 when you are making quite a bit of power 400+. Other than that you aren't going to gain a darn thing..........it's like breathing..........you can only inhale so much air when you breath......having more air does no good if you can't get it into your lungs..........same thing with a motor.
Just like you don't need a K&N filter the size of a 5 gallon bucket do you?........lol
Old May 17, 2004 | 07:39 PM
  #24
Nestromo's Avatar
No, but this does meant hat those of us making 290-310RWHP will pretty much see NOTHING for our $350 "investment". It's good info.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
TitoPR221
May 26, 2015 12:20 AM
maybe2fast
Mar 26, 2015 08:34 AM
squarehead
Nov 21, 2014 08:02 PM
